incidents-responders in List Incidents API are empty
Hi all,
I’ve been creating simple script that calls List Incidents API (DOCS: https://developer.pagerduty.com/api-reference/9d0b4b12e36f9-list-incidents).
The incidents_responders field is always returning empty array. How to get them?
Also (if List Incidents API are cannot get incidents_responders) which API then?
Thank you!
Update 1:
I tried to add responders manually, and the API now returns the manually added responders. Is it need to be added manually to get responders detail?
Hi, I have had similar struggles receiving responder/user/assignee information from the incidents API. I have worked around this by also retrieving the logs and extracting the data from there. I know this is far form ideal but I hope it helps.
Hi Raditya! I just tested this and it seems you need to specify that you want to include the assignees and acknowledgers in your query, like so:
curl --request GET 'https://api.pagerduty.com/incidents?include[]=assignees,acknowledgers'
When including these query params I’m able to see the incident_responders in the response. I hope this helps!
Luke S.
Technical Support Specialist
PagerDuty Support Team
This doesn’t seem to work for querying resolved incidents, also it doesn’t seem to be a valid field value according to https://developer.pagerduty.com/api-reference/9d0b4b12e36f9-list-incidents#Query-Parameters ?
